how can i add google maps to a MIP plugin in xprotect smart client ?
There is no sample doing this, but there is a sample doing a plugin that utilize GMap.Net. I hope the sample will give you sufficient clues.
The sample I suggest you explore is the Smart Client Location View plugin sample. https://doc.developer.milestonesys.com/html/index.html?base=samples/locationview_sample.html&tree=tree_1.html
thanks but i already tried to use GMap.Net but i couldn’t add GMap control in the tool box. the error message translated was : gmap.net.core.dll does not contain any component that can be placed in the toolbox
Does the Location View plugin sample work for you (unmodified)?
what do you mean by Location View plugin ?
if you mean the item view (where supposed displayed google Maps) it works normally .
Let us continue this Q and A in the following page because this is duplicated –
https://developer.milestonesys.com/s/question/0D53X00007HqrOdSAJ/can-not-use-gmapnet
