How can I get a copy of MIP SDK 2019 R3? -- I need to support a customer? - 2020 versions are posted.
We always recommend to use newest SDK - https://developer.milestonesys.com/s/article/about-MIP-SDK-compatibility-with-XProtect-product-versions
HI Rie, Thank you for the best practice instruction. However, we are working on a specific concern at an existing customer site and should be using the same version as on site.
Hi Jennifer,
You can download the 2019 R3 version from here: http://download.milestonesys.com/MIPSDK/MIPSDK_Installer_2019R3.msi
Which can of course be valid if you want to have the exact same code as is on site.
However, I just want to repeat what Rie said, that using the latest SDK is always recommended no matter what VMS version is running on site (except if it is one of the discontinued ones), since newer SDK might contain bug fixes the older one doesn’t.
Best regards,
Peter
