I’m developing a web application and I need to view the camera stream and recordings, I’m using the documentation endpoints and I can’t get the URL of the camera stream.
Documentation: https://doc.developer.milestonesys.com/mipvmsapi/
If you want to use mobile SDK, please see this link –
https://doc.developer.milestonesys.com/mipsdkmobile/
and click “Web” https://doc.developer.milestonesys.com/mipsdkmobile/index.html?base=content_5.html&tree=tree_5.html
Or, if you want to use Web RTC (JavaScript Client), then please see this sample -
I want to use the mobile sdk, I downloaded the XProtect Mobile Server but the sample files are not downloaded with it.
I downloaded some examples from github and created the routes, but it only downloads an html
Hi, Tulio,
In this video tutorial, you can see how to open the samples. https://www.youtube.com/watch?v=p9tdFsCYdWM&ab_channel=MilestoneDeveloperCommunity
or this documentation in the web tab https://doc.developer.milestonesys.com/mipsdkmobile/
