Hi Veselina,
Yes, you can do that in several ways. In general you have to get a playback stream and provide two other parameters when using RequestStream
or ChangeStream commands (depending on whether you want to request a new stream or change an existing one).
The parameters are:
- SeekType with value “Time” and
- Time with value the timestamp you want to provide.
To get a playback stream you need to set parameter SignalType to “Playback” when requesting or changing a stream.
You can check the following sample for how to request a playback stream:
[path_to_where_your_WebClient_is]\XPMobileSDK\Samples\Video\videoSample.html
After requesting a playback stream you can use the XPMobileSDK.playbackGoTo function (check it in [path_to_where_your_WebClient_is]\XPMobileSDK\XPMobileSDK.js) which is basically a wrapper of ChangeStream command providing SeekType and Time parameters for you.
I hope this helps.
