How can I use Config API client for getting custom properties of camera by logging in as Basic User?
The Config API Client sample works with basic authentication users the same way as it does for Windows/AD users.
Please note that the user must have the proper rights, try first with a user in the Administrators role.
I did the test.
I used the Admin Tab plugin sample to make sure I had a custom property.
https://doc.developer.milestonesys.com/html/index.html?base=samples/pluginsamples/admintabplugin/readme.html&tree=tree_1.html
With the sample plugin deployed I opened the Management Client and added properties.
I then opened the Config API Client sample and logged in with my basic admin user, I then found:
