How can I use mobile server adaptive steaming with mobile SDK?
Hi APAC :slight_smile:
If client wants to use Adaptive Streaming, he should provide when calling Login command.
If VMS has proper license including this feature, and if administrator has allowed the feature in Management Client, then the Login response will also have Value=“Yes”.
Br,
Nikolay
Is this helpful enough, or did I misunderstand the question?
Maybe you need to initiate video from a particular stream?
Please contact me directly in Teams if you need further assistance.
Thanks @Nikolay Dimitrov​. it helps!
