Through Milestone XProtect Management Client we can get this table. Is it possible to get this value through Component integration?
I have found a way of getting it using SmartSearch example:
private String getUserPTZSession(Item item)
RecorderCommandService rcs = new RecorderCommandService();
Item recorderItem = item.GetParent();
String recorderAddress = recorderItem.FQID.ServerId.ServerHostname;
int recorderPort = recorderItem.FQID.ServerId.Serverport;
String serverUri = String.Format("[http://{0}:{1}/RecorderCommandService/RecorderCommandService.asmx](http://%7B0%7D:%7B1%7D/RecorderCommandService/RecorderCommandService.asmx)", recorderAddress, recorderPort);
rcs.Url = serverUri;
LoginSettings ls = LoginSettingsCache.GetLoginSettings([EnvironmentManager.Instance.MasterSite.ServerId.Id](https://EnvironmentManager.Instance.MasterSite.ServerId.Id));
PtzSessionInfo ptzSInfo = rcs.PTZGetSessionInfo(ls.Token, item.FQID.ObjectId);
return ptzSInfo.User.DisplayName;
I removed my answer, that said you could not get this setting..
I am happy you found this solution and shared it.
