How do we authenticate using SOAP?
I am having the same issue as outlined in this question but cannot get pass an HTTP 401 response
https://developer.milestonesys.com/s/question/0D53X00006YUsODSA1/protocol-integration-method-cannot-authenticate-using-soap-401-unauthorized-error
I have tried using Postman, Python, and SoapUI but have been unable to make any progress. Here is the raw request and response from Postman:
POST /ServerAPI/ServerCommandService.asmx HTTP/1.1
Authorization: Basic UGVyZWdyaW5lOldlbGNvbWUxMDfh
Content-Type: application/xml
User-Agent: PostmanRuntime/7.24.1
Accept: */*
Cache-Control: no-cache
Postman-Token: 0039f902-07ca-4d5a-9537-5896bb12196a
Host: ip_address
Accept-Encoding: gzip, deflate, br
Connection: keep-alive
Content-Length: 442
<soap:Envelope xmlns:xsi=http://www.w3.org/2001/XMLSchema-instance xmlns:xsd=“http://www.w3.org/2001/XMLSchema” xmlns:soap=“http://schemas.xmlsoap.org/soap/envelope/”>
soap:Body
<Login xmlns=“http://videoos.net/2/XProtectCSServerCommand”>
fc0352e7-6a7a-418b-ad1d-2f16c09adddf
</soap:Body>
</soap:Envelope>
HTTP/1.1 401 Unauthorized
Content-Type: text/html
Server: Microsoft-IIS/10.0
WWW-Authenticate: Negotiate
WWW-Authenticate: NTLM
X-Powered-By: ASP.NET
X-Frame-Options: SAMEORIGIN
Date: Tue, 05 May 2020 21:09:29 GMT
Content-Length: 1293
401 - Unauthorized: Access is denied due to invalid credentials.
Server Error
You do not have permission to view this directory or page using the credentials that you supplied.
Since you are using the basic authentication method I assume you are using an XProtect basic user?
If that is indeed the case you need to use SSL and log in to the server using this URI instead: ManagementServer/ServerCommandService.svc
As is also listed on this page in the documentation: https://doc.developer.milestonesys.com/html/index.html?base=content_0.html&tree=tree_3.html
For further help on how to log in in a protocol integration please have a look at the LoginDotNetSoap protocol sample in the SDK. It is in C#, but especially for basic users it should be a fairly straight-forward conversion to most other languages.
The Milestone instance is running on XProtect Corporate 2018 R3 and we are using the BasicUser for authentication. Following the exact instructions on the Milestone documentation and the LoginDotNet sample code we still receive 4xx responses.
POST /ManagementServer/ServerCommandService.svc HTTP/1.1
Content-Type: application/soap+xml; charset=utf-8
SOAPAction: http://videoos.net/2/XProtectCSServerCommand/Login
Authorization: Basic UGVyZWdyaW5lOlelcGNvbWUxMDEh
Accept: */*
Postman-Token: 4ce96e70-d5e2-4165-9824-20bf7194bf54
Host: <ip_address>
Content-Length: 442
soap:Body
fc0352e7-6a7a-418b-ad1d-2f16c09adedf
</soap:Body>
</soap:Envelope>
HTTP/1.1 400 Bad Request
Cache-Control: private
X-AspNet-Version: 4.0.30319
Date: Thu, 07 May 2020 15:38:22 GMT
Content-Length: 0
What do we need to change in order to receive a successful response?
Are you using SSL? Basic user login requires usage of HTTPS.
We tried using SSL and disabled verification checks (given self-signing certificate) and that worked. Thank you Peter
He using XProtect Corporate 2018 R3.
I read in the docs “Protocols > ImageServer > ImageServer - Authenticate”:
There are two ways of authenticating with Milestone XProtect servers
  • The SOAP/HTTP-based way, using Windows credentials (username, password)
  • The TCP way, using XProtect Enterprise’s Basic Authentication credentials
and:
  • Basic Authentication Credentials (only works for XProtect Enterprise and XProtect Professional)
  • Windows Credentials (works for both XProtect Enterprise and XProtect Corporate)
So in this case, why did you recommend using SSL with XProtect Corporate?
It conflicts with your documents but worked.
