How do we install App Center with Sandbox / Developer mode enabled?
I have installed latest App Center with version (1.1.328). In the runtime folder I got the attached “how to guide” but it doesn’t specify how i can run it in sandbox, I need it to build apps and test locally.
how-to-guide.pdf (1.6 MB)
Hello @AKB!
Thanks for posting this question as a different topic :wink:
This answer can be found here - if you are asked for a password, it is shared on this post.
In short, these are the arguments you can pass to the installer to install the Sandbox environment:
  • --cluster-sandbox : Set up a local sandbox consisting of a Docker registry and Helm repository allowing you to deploy and install your app locally, before submitting the app.
  • --cluster-dev-mode : Enable Kubernetes & Helm dashboards for monitoring and debugging
  • --cluster-debug : Output verbose installation logs --dbg : Run the UI installer in debug mode
  • --update : To speed up the installation, you can set this flag and it will skip whatever is already installed
Let me know how it goes.
Fer
Developer Resources I cant access this link. Asking for password.
Also the arguments mentioned I have to use them like this right,
runtime-installer-1.1.328.exe --cluster-sandbox
As mentioned before, the password for that entry is shared on this post.
And yes, you need to pass them to the installer call as you mentioned:
i.e.
runtime-installer-1.1.328.exe --cluster-sandbox --cluster-dev-mode --update
Thanks, I will try this and share my finding.
Hello. I am having issues installing the runtime and would like to reach the documentation. But it seems that the page with the password is gone. Could someone share it? Thanks
Please note:
The Milestone XProtect App Platform / MIP Runtime Platform is currently in a pilot phase.
Because of this, access is handled through a dedicated Pilot Partner group on this forum.
:locked_with_key: How to get access
  1. Log in or register on the Developer Forum.
  2. In the left‑hand menu, click More → Groups.
  3. Find the private group “MIP Runtime Platform Pilot Partners”.
  4. Click the group and request access.
:white_check_mark: Access is typically granted within one business day.
:open_file_folder: What you will see after access is granted
Once you are a member of the group:
  • Go to Categories in the left‑hand panel.
  • Select All categories.
  • You will now see new pilot‑only categories, including:
    • MIP Runtime Platform
    • App Builder
    • App Center & Runtime Platform
