Rie, Thanks for the quick response. We are using the current versions of everything (2019 R2). Also, we installed the VMS without any encryption enabled - how would we verify this? Perhaps you can recreate the issue on your end.
Please verify, when you test with the same user in the Smart Client on the same remote PC you get the images from the same camera and no error message?
My first idea would be the network communication, that networking does not work correctly, a firewall is blocking or something similar. I would however expect this kind of issue to be the same for the Smart Client as for the PlaybackWpfUser component sample. Can you test with firewall turned off?
Can you please test with Smart Client? Your attached image seems like Web Client, so please test it with using Smart Client. Click Windows icon → select XProtect Smart Client.
We have never seen this issue before that SC can login and MIP SK based app cannot when using the same user on the same PC. To troubleshoot: Could you please add a new user in administrator role and test it again with that user?
If you run the MIP SDK based app in the server directly, does it work there?
We tried several different users with various permissions with no change in the results. Connecting directly on the server via local host and IP address work as expected. How would we test a remote connection from the server to itself? How does this help diagnose why the SDK has issues and the Smart Client does not?
Prepare a Smart Client view with one camera, let us know the camera for the test (make, model and firmware version), let us know the setting of the camera (settings and streams tab).
First make a trace where you open the Smart Client on the camera view (setup above) and goes into playback mode. As soon as you are in playback mode and see the view has images please stop tracing and save the trace for us.
Second make a trace where you open the PlaybackWpfUser on the camera. When you see the “connecting” message let the trace run another 5 seconds or so and then stop the trace and save the trace for us.
It is important that the two traces are tracing the use the same remote PC, using the same user, using the same camera.
