How is the Login token generated?
To log in using SOAP web services, Login object needs a token.
public class Login {
@XmlElement(required = true)
protected String instanceId;
protected String currentToken;
How is the token generated ?
What is the instanceId ?
Is this the username ?
The token is generated by the Server Command Service, see-
https://doc.developer.milestonesys.com/html/index.html?base=gettingstarted/intro_soap_protocols.html&tree=tree_3.html
https://doc.developer.milestonesys.com/html/index.html?base=serversoaphelp/index.html&tree=tree_3.html
Please explore following sample Login .Net SOAP-
https://doc.developer.milestonesys.com/html/index.html?base=samples/logindotnetsoap.html&tree=tree_3.html
