How many cameras can an Open Network Bridge server handle ?
Are there limits to how many cameras an Open Network Bridge server can handle ?
As a static configuration (i.e. linking x cameras to a server in the XProtect system configuration) AND/OR dynamically (i.e. efficiently serving x RTSP streams from x cameras at the same time).
Can I set 100, 500, 1000 camera to a unique ONB server instance ?
Is there a Milestone document settling this ?
Hi Jean-Jacques,
Static limitation, as you call it - no.
Dynamically - yes, there is a limitation. Take a look at this forum thread for more info.
Br,
Nikolay
