I’m working with dynamic views in floating windows. Mainly to create a specialized alarm preview depending on the alarm to see. Given the case, we have a viewItemPlugin that needs to appear within the window if we get a particular alarm. How should the object be instantiated to work in the same way they do when in the usual context? Is there a specific way as if you were creating a new window? or do we have to approach them differently?
Does the Smart Client Insert Camera plugin sample give the answer?
Yes, It does the trick! Thank you!
