I would like to implement a plugin that allows the user to manage the bounding box providers (exactly as is implemented in the Setup → Properties → Display Settings panel of a camera) inside the plugin view :
The user should be able to select dynamically which metadata provider should be displayed or not. I saw in a similar post that you suggested using ImageViewerAddOn.ShowMetadataOverlay variable, but this way it is not possible to display a specific bounding box provider.
Do you have any idea how could I implement this ?
Best Regards
