How to add a driver framework plugin in its own hardware section?
Currently, it seems that the only way to add new drivers to Milestone is under the “Other” section. I have seen the driver show up under “ORBNET” once but it was in an older version and I have not been able to get that to work again.
Specifically, how could we add the driver to “ORBNET” instead of “Other”?
When you create a new driver, you specify a category.
No matter the category, if you have one driver deployed it is placed in the “Other” category in the Management Client.
If you have two or more drivers deployed your driver is placed in that category in the Management Client.
The design is that there should be no category with only one member.
Thanks Rie. So is it possible to add a driver to an existing category, e.g. Mobotix?
Yes, it is.
