How to call MIP SDK to hide setup,Or let setup display on the right side
Under the same smart client,I configure the system so that Setup mode is available to the user。
System Monitor plug-in is not setup
Snipaste_333333333333333333
My plug-in has setup
Setup is not available for the built-in System Monitor, this is by design.
If you make your own Workspace Toolbar button it can display if you put following code in your WorkSpaceToolbarPlugin
WorkSpaceToolbarPlaceDefinition.WorkSpaceIds =
    new List<Guid>()
        ClientControl.SystemMonitorBuildInWorkSpaceId
If my answer is unclear do an experiment. Modify the SCToolbarPlugin sample. In SetViewItemBackgroundColorWorkSpaceToolbarPlugin.cs line 63 add ClientControl.SystemMonitorBuildInWorkSpaceId to the list.
