How to change ConcurrentLicense to the new license system XCO 2020 R3
We have a plugin that use the ConcurrentLicenseManager. We need this plugin also for XCO 2020 R3.
How can I change this license system to match the new requirements? We used
this plugin in the SC to add toolbar items. How can I do a License register, like in ConcurrentLicense?
Best regards,
Andreas
As you are probably aware ConcurrentLicenseManager was discontinued in version 2020 R2. The functionality can, however, fairly easily be mimicked by making your own event server plugin that keeps count of number of current instances and compares that towards the MIP license channel count. Communication with the event server plugin can be done using MIP message communication. We apologize for the extra work needed doing this, but due to security issues with the old solution we had to break compatibility anyways and since it is just a special case of normal licensing we decided to no longer include dedicated functionality for it.
Ok, many thanks for your answer.
