I have ONVIF Bridge Server installed on a server named cctv-mgmt with a local IP address of 192.168.0.238. I have port forwarding to a public address on my router. Connects to the server by Onvif Device Manager using a public address. But when I want to display live video, it doesn’t work because the local server address is given in the RTSP address.
How to change the RTSP server address in the RTSP stream address which is given in the RTSP stream address?
