How to debug high CPU usage of ISS Worker VideoOS App pool ?
I would like to know how to debug the high CPU usage of the iss Worker Videoos Management Server App pool ?
I have several event server plugin running that i suspect to be the cause of my issue with the high CPU usage but how to know which one is causing the problem in a production environment ?
Regards,
Capture
To debug your event server plugin might be helpful for you to investigate which one uses high CPU, please see this article -
https://developer.milestonesys.com/s/article/debugging-techniques-for-Event-Server-plugins
I already use those techniques.
But my issue is that the process of the Milestone XProtect Event Server is not using a lot of CPU
Capture event serverSo i can’t figure out which process is causing the issue by attaching to the Event Server Process.
I’m looking for a way to investigate the high CPU usage on the VideoOS Management Server AppPool in IIS.
When this is not your plugin causing this, we are then talking about a general performance issue of XProtect. We have no information or methods on this in the MIP SDK Team. Please try to ask the Support Community.
