How to display the event rule box in the Milestone Coporate?
The current situation: Dahua and Miletone are integrating by ONVIF, and ONVIF support very well.
The target: the camera have the people counting function, we hope to display the red rule box in the Smart Client.
The current issue: The onvif don’t contain the peopel counting event bouding box information, so we want to extend the ONVIF data, when we extend these information to the ONVIF, smart client can not anaysis this entend onvif data.
When we try to use MIP SDK to get this information, whcih also can not be got and display.(the following is the wireshark trace)
Would you please help to guide us? This is quite important.
Thanks so much.
The following is the wireshark trace which is used MIP SDK
Note that out of the box the Smart Client only supports display of bounding boxes, you can submit other kinds of metadata but in that case you will have to develop a plugin to display the metadata in the Smart Client.
But I have a feeling that bounding boxes might be all you need..
If you explore the Bounding Box Metadata Provider sample - https://doc.developer.milestonesys.com/html/index.html?base=samples/boundingboxmetadataprovider.html&tree=tree_2.html - you will notice how it extends the bounding box xml with extra text. I hope this is the hint you need.
