Hi, I want to draw rectangle over image viewer Control in the milestone client while displaying live video.
Take a look at the SmartClient plugin example called VideoAnayltics
It has sample code that draws text and rectangles as an overlay on the ImageViewer control.
I have a WinForms application (that was based on the VideoViewer sample) which also is uses ImageViewer control and adds overlay text and rectanbles.
With the ImageView Control I register for the ImageDisplayedEventan
In the event handler I build a list of Shapes
List<System.Windows.Shapes.Shape> shapes = new List<System.Windows.Shapes.Shape>();
Then I add the list to the ImageViewer
imageViewerControl1.ShapesOverlayAdd(shapes, overlayParams);
When you need a new list of shapes, you can remove the old list.
Hi, @Roger Hardiman @Bo Ellegård Andersen (Milestone Systems) .
I’ve put my plug-in in the milestone client. the plugin has an image viewer control.
i wish to implement a flow like this:
- User uses mouse to drag a shape (rectangle or polygon) (it’s the Region of interest)
- the shape is being drawn on the image viewer video as the drag continues
- user finish the drag → the shape stays on the image viewer control
Can you suggest the best practice for this?
thank you.
I have done something similar in a stand alone application using ImageView Control. I assume it will work inside SmartClient.
With ImageViewControl you can register for Click Events and Mouse Move Events.
I use the Click Event to store the Mouse.X and Mouse.Y position and the Mouse Move Event to draw a rectangle using the ‘Shape Overlays’. (I update ShapeOverlay on every mouse move)
You will have to do some maths on the X and Y positions.
I found the The X and Y positions relate to the whole ‘ImageViewControl’ area so you need do to some maths to convert these into the position in the camera image.
