How to get camera groups and Roles in Milestone Xprotect export without giving basic user admin role.
I am trying to retrieve the list of camera groups and list of roles from the Milestone sdk.
i am using the code bellow:
ManagementServer ms = new ManagementServer(VideoOS.Platform.EnvironmentManager.Instance.MasterSite);
var roles = ms.RoleFolder.Roles;
var rooms= ms.CameraGroupFolder.CameraGroups;
this code works on Milestone XProtect Corporate only if i give the basic user read right on the management server in the overall security tab. This option is not available on the other versions.
May you let us know a workaround for this problem?
Thanks.
  1. This is by design.
  2. In Professional+, user should be as administrator when you use Configuration API.
  3. In Corporate, basic user without admin-group can use Configuration API because Corporate has differentiated admin rights functionality.
So if you want to use Configuration API in Professional+ then user should be in Administrator group.
You can get CameraGroups with MIP configuration, please explore Configuration Access - https://doc.developer.milestonesys.com/html/index.html?base=samples/configaccess_sample.html&tree=tree_2.html
