I want to find the start and end time of a recorded video in RTSP format using the web SDK.
I believe GetSequences, meaning when is there recorded video, is what you are seeking.
Thanks for answering my question.
My questions are mainly two.
Can I check the saved video in RTSP protocol format using WebSDK?
When there is only a start time
When there is both a start time and an end time
In the above two cases, I would like to check the RTSP of the saved video.
I might have given a bad answer. Milestone XProtect does not offer a RTSP streaming service in the core product. RTSP streaming is however part of the add-on product XProtect Open Network Bridge. There are instructions of use in the manual.
https://doc.milestonesys.com/latest/en-US/portal/htm/chapter-page-onvif.htm
The Milestone SDKs, MIP SDK and Mobile SDK, retrieves video in other ways, there is no RTSP involved. GetSequences that I mentioned will only tell you the intervals in which there is anything recorded that can be retrieved.
If use the XProtect Open Network Bridge, as you said before, if there is only a start time in the saved video, or if there is a start time and end time, can it be formatted in RTSP format? I don’t want to use Onvif Specification.
Hi @준호 김,
Have you tried this:
I’ll consider this method too
