What I’ve done so far:
- Fresh, clean install of Win10 Pro (Version 1903, Build 18362.356) 64bit (German) including all available Updates.
- Fresh, clean install of Essentials+ 2019 R2 including Device Pack 105b131
- Ordered a new CRT with Sectigo, generated the .p12 according to the guide here
- Imported the .pfx to the Windows Cert Store, where it validates fine
- Opened the Cert in Mobile Server, where it shows instantly, selected it, confirmed with OK and confirmed UAC with yes as well. After that I can trace with the tray icon that the Mobile Server is restarted. After a few seconds an error message pops up (translated from German): The binding of the Certificate with the HTTPS Port was not successfull. The selected Certificate is not valid. Open Mobile Server Manager and select “Edit Certificate” to chose a valid Certifacte. The Log says:
2019-09-13;11:54:42;Info;PluginManager.Start();Stopped HTTP communication channel on port: 8081
2019-09-13;11:54:42;Error;HttpListenerAsync.ListenerCallback;Der E/A-Vorgang wurde wegen eines Threadendes oder einer Anwendungsanforderung abgebrochen
2019-09-13;11:54:42;Info;PluginManager.Start();Stopped HTTP_DEFAULT communication channel on port: 8081
2019-09-13;11:54:43;-------------------------- Session End
2019-09-13;11:54:54;-------------------------- Version;13.2.502.1
2019-09-13;11:54:54;Local time is now: 11:54:54;Time Zone: UTC+02:00
2019-09-13;11:54:54;LogLevel set to: Info
2019-09-13;11:54:54;Info;Server;Service is starting
2019-09-13;11:54:54;Info;Server;Service is started
2019-09-13;11:54:55;Info;InitializeFromSiteItem;Server sub type: 440, Code base: 2, Version string: 13.2.0.1
2019-09-13;11:54:56;Info;LicenseWrapper;Login is True
2019-09-13;11:54:56;Info;AlarmSecurityManager.TryRefreshUsers;All users list updated.
2019-09-13;11:54:56;Info;MipSdkWrapper.CheckSettings();Number of read configurations: 1
2019-09-13;11:54:56;Info;MipSdkWrapper.GetConfigurationByServerId();Settings has been found.
2019-09-13;11:54:56;Info;Main thread;Current Culture: de-DE
2019-09-13;11:54:56;Info;Main thread;Current UI Culture: de-DE
2019-09-13;11:54:56;Info;AviCodecList.PrintCodecList;Start Codec List
2019-09-13;11:54:56;Info;AviCodecList.PrintCodecList;Intel IYUV Codec
2019-09-13;11:54:56;Info;AviCodecList.PrintCodecList;Microsoft RLE
2019-09-13;11:54:56;Info;AviCodecList.PrintCodecList;Microsoft Video 1
2019-09-13;11:54:56;Info;AviCodecList.PrintCodecList;Microsoft YUV
2019-09-13;11:54:56;Info;AviCodecList.PrintCodecList;End Codec List
2019-09-13;11:54:56;Info;InitFromConfigSettings;outgoingAudioEnabled is True
2019-09-13;11:54:56;Info;InitFromConfigSettings;incomingAudioEnabled is True
2019-09-13;11:54:56;Error;EntryManagerHelper.LoadFromFileStructure;Ein Teil des Pfades “[C:\ProgramData\Milestone\XProtect](file:C:/ProgramData/Milestone/XProtect) Mobile Server\Exports\Investigations” konnte nicht gefunden werden.
2019-09-13;11:54:56;Info;LicenseWrapper;OnlineExpiration is False
2019-09-13;11:54:56;Info;PluginManager.Start();Initialized HTTP communication channel on port: 8081
2019-09-13;11:54:56;Error;System.Exception: Preconditions not met for group HTTPS; bei VideoOS.Mobile.Server.Service.MetaChannel.PluginGroup.Start(Dictionary`2 settings)
2019-09-13;11:54:56;Info;PluginManager.Start();This error might occur due to an incorrect HTTP/HTTPS channel configuration
2019-09-13;11:54:56;Info;PluginManager.Start();Initialized HTTP_DEFAULT communication channel on port: 8081
2019-09-13;11:55:00;Error;DeviceScanner.RequestCallback;Auf das verworfene Objekt kann nicht zugegriffen werden.
Objektname: “VideoOS.Mobile.Windows.Net.MulticastClientImplementer”.
Thank you in advance for any tips and hints!
Harry
