How to integrate video file into milestone
Hello!
I am attempting to stream video from a file(mp4) using C# with OpenCvSharp and pipe it to FFmpeg, which should act as an RTSP server.
My goal is to make the stream accessible via VLC ( as I am using universel driver 1) or Milestone XProtect using their Universal Driver.
Windows 11
FFmpeg version: ffmpeg version N-119444-g2b6303762f-20250506 Copyright (c) 2000-2025 the FFmpeg developers
built with gcc 14.2.0 (crosstool-NG 1.27.0.18_7458341)
OpenCvSharp4 (NuGet)
.NET 9
VLC version: [insert VLC version]
The idea is that I should be able to use rtsp://0.0.0.0:8554/stream as the localhost stream, however it does not work in VLC, which means it does not work in milestone. Have anyone had success with this?
What I have done so far is this:
using OpenCvSharp;
using System;
using System.Diagnostics;
using System.IO;
using System.Runtime.InteropServices;
class Program
    static void Main()
        Console.WriteLine("Enter the path to the video file:");
        string videoPath = Console.ReadLine();
        if (string.IsNullOrEmpty(videoPath))
            Console.WriteLine("Error: No video path provided.");
            return;
        var cap = new VideoCapture(videoPath);
        if (!cap.IsOpened())
            Console.WriteLine("Error: Could not open the video file!");
            return;
        int frameWidth = cap.FrameWidth;
        int frameHeight = cap.FrameHeight;
        double fps = cap.Fps;
        Console.WriteLine($"Resolution: {frameWidth}x{frameHeight}, FPS: {fps}");
        // Start ffmpeg as a local RTSP server
        Process ffmpeg = new Process();
        ffmpeg.StartInfo.FileName = "ffmpeg";
        ffmpeg.StartInfo.Arguments = $"-f rawvideo -pixel_format bgr24 -video_size {frameWidth}x{frameHeight} -framerate {fps} -i - " +
            $"-c:v libx264 -preset ultrafast -tune zerolatency -f rtsp -rtsp_flags listen -rtsp_transport tcp rtsp://0.0.0.0:8554/stream";
        ffmpeg.StartInfo.RedirectStandardInput = true;
        ffmpeg.StartInfo.RedirectStandardError = true;
        ffmpeg.StartInfo.UseShellExecute = false;
        ffmpeg.StartInfo.CreateNoWindow = true;
        ffmpeg.Start();
        // Read and stream frames
        Mat frame = new Mat();
        int frameSize = frameWidth * frameHeight * 3; // BGR24
        byte[] buffer = new byte[frameSize];
        try
            while (true)
                cap.Read(frame);
                if (frame.Empty())
                    break;
                Marshal.Copy(frame.Data, buffer, 0, buffer.Length);
                ffmpeg.StandardInput.BaseStream.Write(buffer, 0, buffer.Length);
                ffmpeg.StandardInput.BaseStream.Flush();
                Console.WriteLine($"Streaming Frame: {frame.Width}x{frame.Height}");
        catch (Exception ex)
            Console.WriteLine($"Exception occurred while streaming: {ex.Message}");
        finally
            cap.Release();
            ffmpeg.StandardInput.Close();
            string ffmpegError = ffmpeg.StandardError.ReadToEnd();
            if (!string.IsNullOrWhiteSpace(ffmpegError))
                Console.WriteLine("FFmpeg error output:");
                Console.WriteLine(ffmpegError);
            ffmpeg.WaitForExit();
            ffmpeg.Close();
            Console.WriteLine("Streaming finished.");
I think it is expected that if it doesn’t work in VLC it doesn’t work in Milestone XProtect using the Universal Driver. It is out of scope for what we in Milestone Support are able to help you with. If you haven’t already I recommend that you try other forums more dedicated to general video streaming. I hope that other users of this forum does have the experience so that they can help you.
Hi Bo, thank you for the reply.
Should it be possible to stream a video feed from mp4 into milestone?
Yes. Using the Universal Driver and RTSP stream the encoding needs to be understood by Milestone XProtect. I believe others have achieved this. Unfortunately there is no sample or similar to guide you. I have a gut feeling that if you have it working in VLC there is a big likelihood it will work in XProtect.
Hi @Mahmud Alasadi
A few years ago I tried the same and described a possible solution using the .NET Framework-based Driver Framework here: Video File Import Driver — Using the Driver Framework to write a Video File Import Driver sample
