How to know if an alarm is active for an item
I have a mip plugin, much like the sensormonitor with our own items/events/…
Is there a way to retrieve whether a Milestone alarm is active for a certain item from within my mip plugin that runs in the Event Server?
Thanks,
Alex
Hi @Alex Van De Velde​ ,
Have a look at AlarmClientManager
You could also have a look at the MIP Plugin example “Alarm Event Viewer”
Hi @Xavier Julies​ .
That’s indeed usefull.
I wondered if there is a function that we can call just to get the alarm state of an item.
Basically knowing when there is a red circle around the item in the map.
Thanks,
Alex
Glad to hear you found it useful! :+1:
Not sure if the alarm client has a method to return active alarms for a specific Item. You could have a look at IAlarmClient. Perhaps you could use the AlarmFilter method, but I haven’t used it myself.
