How to listen Exported data (BLK) with component application
Hi, and thanks in advance
I wrote an application to view Exported data in Milestone format using the “VideoFileviewer” sample
It was very easy, then I’m trying to do the same with the Microphone exported data.
I have red the “AudioDemo” sample to learn how to use the audioPlayerControl.
I created a default server with the uri referred to the exported data,in the same way of case of VideoFileviewer.
I can see the Microphone devices, but I cannot hear the selected one.
By the way I have also inserteda playbackUserControl to try to go to the beginning of frame.
I report the interessed code:
private void btnSelectMicrofone_Click(object sender, EventArgs e)
if (_selectedMic != null)
    \_audioPlayerControl1.Disconnect();
  ItemPickerForm form = new ItemPickerForm();
  form.KindFilter = Kind.Microphone;
  form.AutoAccept = true;
  form.Init(Configuration.Instance.GetItems(ItemHierarchy.Both));
  if (form.ShowDialog() == DialogResult.OK)
    \_selectedMic = form.SelectedItem;
    btnSelectMicrofone.Text = \_selectedMic.Name;
    if (\_playbackUserControlMic == null)
      \_playbackUserControlMic = ClientControl.Instance.GeneratePlaybackUserControl();
      \_playbackUserControlMic.Dock = DockStyle.Top;
      \_playbackUserControlMic.ShowTallUserControl = true;
      \_playbackUserControlMic.ShowTimeSpanControl = true;
      \_playbackUserControlMic.ShowSpeedControl = true;
      \_playbackUserControlMic.Refresh();
      panel2.Controls.Clear();
      panel2.Controls.Add(\_playbackUserControlMic);
    if (\_playbackFQIDMic == null)
      \_playbackFQIDMic = ClientControl.Instance.GeneratePlaybackController();
      \_playbackUserControlMic.Init(\_playbackFQIDMic);
    \_audioPlayerControl1.MicrophoneFQID = \_selectedMic.FQID;
    \_audioPlayerControl1.PlaybackControllerFQID = \_playbackFQIDMic;
    EnvironmentManager.Instance.Mode = Mode.ClientPlayback;
     \_audioPlayerControl1.Initialize();
    \_audioPlayerControl1.Connect();
    \_playbackUserControlMic.Show();
    \_playbackUserControlMic.SetEnabled(true);
    \_audioPlayerControl1.StartBrowse();
    EnvironmentManager.Instance.SendMessage(new VideoOS.Platform.Messaging.Message(
                          VideoOS.Platform.Messaging.MessageId.System.ModeChangeCommand,
                          Mode.ClientPlayback), \_playbackFQIDMic);
Can you please explore a sample VideoViewer2Playback -
https://doc.developer.milestonesys.com/html/index.html?base=samples/videoviewer2playback_sample.html&tree=tree_search.html?search=videoviewer2playback
You will find the following code,
foreach (Item item in related)
	if (item.FQID.Kind == Kind.Microphone)
		_related1Microphone = item;
		_audioPlayerControl1Microphone.MicrophoneFQID = _related1Microphone.FQID;
		break;
     	if (item.FQID.Kind == Kind.Speaker)
		_related1Speaker = item;
              _audioPlayerControl1Speaker.SpeakerFQID = _related1Speaker.FQID;
              break;
You need to set up with Microphone’s and Speaker’s FQID.
Thanks Rie Kito,
I saw the sample but I’m triyng to attach to exported Data in Milestone format not to a classic recording server.
My related item are empty becouse I can connect in a mutually exclusive way to the video part or the audio part
if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
      **\_selectedStoragePath = folderBrowserDialog1.SelectedPath;**
    **else**
      **return;**
    **DirectoryInfo di = new DirectoryInfo(\_selectedStoragePath);**
    **if (File.Exists(Path.Combine(\_selectedStoragePath, "cache.xml")) ||**
        **File.Exists(Path.Combine(\_selectedStoragePath, "archives\_cache.xml")))**
        **bool done = false;**
        **string password = "123Stella!!!";**
        **while (!done)**
          **VideoOS.Platform.SDK.Environment.RemoveAllServers();**
          **Uri uri = new Uri("fil[e:\\\\](file:e://)" + \_selectedStoragePath);**
          **VideoOS.Platform.SDK.Environment.AddServer(uri, new System.Net.NetworkCredential("gpalmieri", password));**
          **try**
            **VideoOS.Platform.SDK.Environment.Login(uri);**
            **VideoOS.Platform.SDK.Environment.LoadConfiguration(uri);**
            **done = true;**
          **catch (NotAuthorizedMIPException)**
Yes. You will need to add the Microphone same way as the Camera; from file system. The VideoFileViewer does this for video only you need to do the same with the audio.
