I’m looking for ways to remove hardware using MIPSDK. I found the RecordingServer class in ConfigAddCameras Sample, but it seems to do not have any remove methods. Please help!
You can using Config API, section Recording Servers, sub-section Hardware.
Look at Config API Client sample
Freddy
Thanks to both Freddy and Josh! It works!
Freddy is correct - take a look at the HardwareFolder class which you’ll find as a child property on every recording server instance. It has a DeleteHardware method which takes the config API path of the hardware object which looks like “Hardware[guid]”
