How to resolve this problem mobile server error connection to mobile service.
This forum is for development related questions only. Please post your question on the normal support forums or contact your Milestone support channel.
Peter is correct,
You shouldn’t ask such questions here.
Although you should check if the port 8000 is not occupied by the another program. This is the default port used from communication between manager and service prior version 12.2.
Otherwise you could check mobile server log file for errors / exceptions.
