Currently, I have a Network Bridge which is added to my Milestone Project as an Onvif Camera. It supports up to 80 Digital Outputs and 60 Digital Inputs. Milestone polls the device and receives the correct amount of IO ports. When I activate one of the
Digital Outputs nothing is happening. I can see that Milestone says the event was handled correctly however my light associated with that output is not turning on. I have run a Wireshark and I cannot see any request from the Milestone server going to the network bridge which is something I have been able to see with similar VMS software when integrating the network bridge. Ideally, I would like a way to see the logging information to see exactly what Milestone is doing when I activate the Digital Output.
