hi,
i am using this code to retrieve IP speaker and output. but it’s not retrieve the disable IP Speaker and output(beacon).
List<VideoOS.Platform.Item> oItems = oInstance.GetItems(ItemHierarchy.SystemDefined);
i have try using this code to retrieve the disable item, however it’s return the all the camera’s output and speaker as well. is there anyway to filter to retrieve the disable IP Speaker and output(beacon) only?
List<VideoOS.Platform.Item> disableItem = VideoOS.Platform.SDK.Environment.GetDisabledDevices(oInstance.ServerFQID.ServerId.Id);
thank you
