How to select an audio output device?
My PC has several audio devices. In the Audio demo application included in MIPSDK, I can select an audio input device and connect it, but I can not select an audio output device. Can I select an audio output device using AudioPlayerControl?
The Audio output device I said is not a IP remote device but an embedded audio device such as HDMI or Displayport.
I believe you can select the audio output through Windows. Right click on the speaker icon on the Windows taskbar and then click “Playback device.”. Set the HDMI / DisplayPort as default.
Is it possible to select by software using the SDK?
