We have a View item plugin that should ‘advertise’ the currently selected camer - the camera being displayed in the view item plugin - in the smart client it way, that a built in hotspot window is picking up the camera and shows this camera’s video feed.
Is there a special message or property that I would need to send or set?
The Hotspot sample does not really help. I don’t want to implement my own hotspot. I would like to use the built-in hotsspot and get the ‘active’ camera (which is processed within my view item) displayed in the built-in hotspot.
Now - the hotspot sample help to a certain extent. The built in hotspot is picking up my camera, as long as the hotspot sample’s floating window is active. When i close the floating window, the camera is no longer picked up.
For a better understanding, i’ll add some screenshots.
Now, I do realize that the background plugin in the hotspot plugin is sending the ‘SetCameraInView’ command, and I assume that this is somehow triggering the functionality I am looking for. But is that the way forward without the hotspot plugin being active? Do need to send this message in myself? Actually that would be incorrect, because I am not inserting a new camera into a view.
Any help is apprechiated.
The following images show the ‘basic setup’. 2x2 view and in the bottom right view item, we have the buil-in hotspot and 2 view item plugins on the left side. With the hotspot plugin being active, the built-in hotspot (bottom right) gets poulated with the camera of the ‘active view item’. In case the floating hotspot windows is closed, it does no longer work.
