Start and Stop Commands work only for the server that is populated with EnvironmentManager.Instance. For other server no action takes place. Any possible way to send commands to multiple dvr’s. I tried using MessageCommunication class as well but was not successful.
Try this way.
Take the two buttons (or the actions) from the VideoViewer sample:
private void OnStartRecording1(object sender, EventArgs e)
if (_selectItem1 != null)
EnvironmentManager.Instance.SendMessage(
new VideoOS.Platform.Messaging.Message(MessageId.Control.StartRecordingCommand), _selectItem1.FQID);
private void OnStopRecording1(object sender, EventArgs e)
new VideoOS.Platform.Messaging.Message(MessageId.Control.StopRecordingCommand), _selectItem1.FQID);
and put them in the MultiSiteViewer instead.
For me this works as expected.
This should convince you that you can use this with multiple sites or servers.
