how to show live camera feed with PTZ controls option in web application
Hi
We have to develop a web application for one of our clients to show live camera feed with PTZ controls option. I have the following concerns.
1-I am a little bit confused about Milestone SDK and Milestone Mobile SDk which one should i use ?
2- At the moment, we don’t have access to client’s environment/live feed. Is there any test environment/server or test cameras link available for development purposes to show them a POC (proof of concept) ?
Your response will highly appreciated.
thanks
Shahzad
  1. For a web application is the Mobile SDK most likely the better choice.
https://doc.developer.milestonesys.com/mipsdkmobile/
  1. An easy option is to use the DirectShow driver and use a video file as the source of the video. DirectShow driver is in the legacy driver pack..
https://supportcommunity.milestonesys.com/s/article/Set-up-DirectShow-Driver
Thank you so much for your swift reply.
I will check .
I was installing XProtect Corporate on my machine and got this message
“A system error has occurred during installation..”
can you please check the attached log file. do i need to install XProtect corporate for development or not?
The last question is on a general XProtect VMS situation not MIP SDK development. Please see if you find troubleshooting information in the Support Community knowledge base articles or ask the support community..
