You might want to define in what Environments the current background task should be started. In this case, please find following code;
public override List<EnvironmentType> TargetEnvironments
get { return new List<EnvironmentType>() { EnvironmentType.Service }; } // Default will run in the Event Server
EnvironmentType.Service means that this works in the Event Server and this is a default setting. If you change the code in the following way, then you will be able to see messagebox when you start Management Client, Smart Client and Event Server.
get { return new List<EnvironmentType>() { EnvironmentType.Service, EnvironmentType.SmartClient, EnvironmentType.Administration }; }
If TargetEnvironments is correctly returned the BackGround plugin should start automatically. Did you try this? Or did you already have your workaround implemented?
