How to use HTTPS to access recorderstatusservice2?
How to use https to access recorderstatusservice2 ?
I only know http interface:
h ttp://x.x.x.x:7563/recorderstatusservice/recorderstatusservice2.asmx
May I use https protocal to get recordstatus? which port should I use?
My version is corportate 2019R1.
With XProtect 2019R1 Milestone introduced SSL/TLS certificate-based encryption of all communication between the Recording Server and the servers and clients connected to it.
This is all or nothing, if you enable the Recording Server encryption it is on all interfaces not just the recorderstatusservice2
https://developer.milestonesys.com/s/question/0D50O00005UTl8nSAD/breaking-change-in-upcoming-2019-r1-release-for-component-and-protocol-integrations
https://content.milestonesys.com/web/555c7ed74c3ebb44/xprotect-2019-r1-materials/?mediaId=A94C1207-7450-4FB2-9DB6BD2FAD13717D
See also “Recording server data encryption (explained)” in the Manual or in the (F1) help system.
​I finished checking, but did not saw where can show me how to configure recorder server for supportting https protocal.
Could you please tell me how to configure recorder server for supportting https portocal?
Please use the manual or the help (F1) from the Management Client and find “Enable encryption to clients and services”
