I am developing a plugin into Xprotect and one of the requirements of the software I’m integrating with is to use OpenCV to access an ONVIF bridge stream for cameras. I have the ONVIF bridge running successfully (can connect to the ONVIF created URL using VLC), but OpenCV’s videocapture is not seeing anything when I try to connect using the same URL that is working in VLC. Does anyone have any insight on this issue?
Thanks in advance for any response.
