I am not sure about where to start with this, I take it that I will need a RS485 to relay driver board to achieve this, but I am not sure about how to do this using MIPS SDK and C#.
Can anybody point me in the right direction?
The MIP SDK does not have any functionality for RS485 or similar. Once you can do this from you C# code you will be able to do it also in a MIP SDK based integration, both standalone or plugin.
So my advise on RS485 would be to search in other resources or forums..
I hope it makes sense.
