I downloaded LiveVideoSample and tried to connect to Milestone's server but it keeps telling my coulnd't connect, However i managed to connect to the server with official milestone android app using the same IP address, port ,Username and password .
Hi Mostafa,
I suppose you are talking about Android “LiveVideoSample”, right ?
correct!
Are you’re running the sample on the same device as the ‘official’ app?
Could you provide a bit more details? For example, which Android version is installed on the device?
i’m running both on the same device, infinix note 3
with android version 6.0
Android 6 is supported by the Mobile SDK, so it should be something else.
May be you could inspect the logcat output and check for some error messages, exceptions or such?
Or copy-paste the server address from the Milestone client, to make sure it has not been misspelled in the live video sample?
