2024-01-15 09:12:05.782 UTC+01:00 Info ServiceChannelWallClient ServiceChannelClient: Server error occured.
2024-01-15 13:46:07.495 UTC+01:00 Info ServiceChannelManager ConfigurationChanged received: Hardware c8d89c88-29f6-4276-b5a8-e6f169b3bb14 : Updated
2024-01-15 13:46:10.541 UTC+01:00 Info ServiceChannelManager ConfigurationChanged received: Hardware c8d89c88-29f6-4276-b5a8-e6f169b3bb14 : Updated
2024-01-15 13:47:36.384 UTC+01:00 Info ServiceChannelWallClient ServiceChannelClient: Server error occured.
2024-01-15 14:11:13.060 UTC+01:00 Info CUDABackgroundPlugin Plugin closing.
2024-01-15 14:11:16.169 UTC+01:00 Info CommunicationService background thread Now stopping…
2024-01-15 14:11:30.736 UTC+01:00 Info PluginLoader VideoWallHelper, loaded from:[C:\Program](file:C:/Program) Files\Milestone\XProtect Event Server\VideoOS.Platform.dll
2024-01-15 14:11:30.736 UTC+01:00 Info PluginLoader GisMapLocationHelper, loaded from:[C:\Program](file:C:/Program) Files\Milestone\XProtect Event Server\VideoOS.Platform.dll
2024-01-15 14:11:30.736 UTC+01:00 Info PluginLoader Analytics Events, loaded from:[C:\Program](file:C:/Program) Files\Milestone\XProtect Event Server\MIPPlugins\VideoOS.Analytics.Events\VideoOS.Analytics.Events.dll
2024-01-15 14:11:30.736 UTC+01:00 Info PluginLoader Customer dashboard plugin, loaded from:[C:\Program](file:C:/Program) Files\Milestone\XProtect Event Server\MIPPlugins\VideoOS.CUDAPlugin\VideoOS.CUDAPlugin.dll
2024-01-15 14:11:30.736 UTC+01:00 Info PluginLoader Generic Events, loaded from:[C:\Program](file:C:/Program) Files\Milestone\XProtect Event Server\MIPPlugins\VideoOS.Generic.Events\VideoOS.Generic.Events.dll
2024-01-15 14:11:30.736 UTC+01:00 Info PluginLoader Webhooks Plugin, loaded from:[C:\Program](file:C:/Program) Files\Milestone\XProtect Event Server\MIPPlugins\VideoOS.Plugins.WebHooks\VideoOS.Plugins.WebHooks.dll
2024-01-15 14:11:30.798 UTC+01:00 Info CUDABackgroundPlugin Plugin Construction.
2024-01-15 14:11:30.814 UTC+01:00 Info GetRegisteredServiceUriInfo Warning: Network credentials has been provided, method is obsolete. Use the calling method without network credentials.
2024-01-15 14:11:30.830 UTC+01:00 Info ServiceUtil.CreateServiceRegistrationProxy Warning: Unable to look up whether provided user is a basic user (therefore assuming it is not) for server: sensor.orebroll.se
2024-01-15 14:11:31.064 UTC+01:00 Info CommunicationService background thread Now starting…
2024-01-15 14:11:31.064 UTC+01:00 Info GetRegisteredServiceUriInfo Warning: Network credentials has been provided, method is obsolete. Use the calling method without network credentials.
2024-01-15 14:11:31.064 UTC+01:00 Info CommunicationService:URL net.tcp://SENSOR:22333/CommunicationService
2024-01-15 14:11:32.482 UTC+01:00 Info LoginSettings.ctor Constructed for instance=268e5ac1-be66-4f4b-9cd1-229fe4843760, IdentityTokenCache is null
2024-01-15 14:11:35.591 UTC+01:00 Error CommunicationService Same messageId being registered multiple times: Optimizer.Hello.v1
2024-01-15 14:11:37.606 UTC+01:00 Info CUDABackgroundPlugin Plugin init.
2024-01-15 14:11:37.872 UTC+01:00 Info LicenseManager Licenses: Name=XPIM, Type=XPIM, Counter=1
2024-01-15 14:11:37.872 UTC+01:00 Info LicenseManager Registrations: Name=Door, Type=XPAC, Counter=0
2024-01-15 14:11:37.888 UTC+01:00 Info ReservedLicenseManager GetLicenseInformation - Name=Door, Count=0, Type=XPAC
2024-01-15 14:11:37.888 UTC+01:00 Info StartAfterTokenAndConfigurationReady MIP succesfully started
2024-01-15 14:11:38.060 UTC+01:00 Info GetRegisteredServiceUriInfo Warning: Network credentials has been provided, method is obsolete. Use the calling method without network credentials.
