I have an Axis A9188 I/O - Relay board. nk you
I can only correctly retrieve the state of the output device if I activate it within the Milestone system.
I need to be able to retrieve the output state using the Milestone API with the output device being activated from outside Milestone.
Here is the event rule in the A9188 interface:
