I want to get Monitor, Layout and Camera Item via FQID from server.
For cameras it is working! Why not for Monitors and Layouts?
private static List CreateList(Item item, string key)
       if (item.Properties.ContainsKey(key))
           String selectedList = item.Properties\[key\];
           XmlDocument doc = new XmlDocument
               InnerXml = selectedList
           List<Item> list = new List<Item>();
           XmlNode selectedNode = doc.SelectSingleNode(key);
           foreach (XmlNode itemNode in selectedNode.SelectNodes("Item"))
               FQID fqidItem = new FQID(itemNode.SelectSingleNode("FQID"));
               Item \_serverItem = Configuration.Instance.GetItem(fqidItem);
               if (\_serverItem != null)
                   list.Add(\_serverItem);
           return list;
       return null;
For Monitors and Layouts “Item _serverItem = Configuration.Instance.GetItem(fqidItem);” gets null.
You can only get the Monitors and Layouts when you are in a Smart Client plug-in. Perhaps you can run the ConfigDump tool plugin sample and see if it includes the information you seek.
