I think the target you need to use is objectId. (I am not sure but hope it fits.)
http://doc.developer.milestonesys.com/html/index.html?base=miphelp/namespace_video_o_s_1_1_platform_1_1_proxy_1_1_alarm.html#a8d56f2168e6b2e9560be6bda2e5d4854&tree=tree_search.html?search=target
enum VideoOS.Platform.Proxy.Alarm.Target
The target is the data field on which both the filter conditions and order by statements are constructed.
Enumerator:
LocalId
Id
State
Priority
Timestamp
SourceName
Name
AssignedTo
Type
RuleType
Location
Message
CustomTag
VendorName
ObjectValue
Description
ObjectId
Modified
PriorityName
Category
CategoryName
StateName
Bo, The following soap envelop
<soapenv:Envelope xmlns:soapenv=“http://schemas.xmlsoap.org/soap/envelope/” xmlns:cen=“http://videoos.net/2/CentralServerAlarmCommand” xmlns:vid=“http://schemas.datacontract.org/2004/07/VideoOS.Platform.Proxy.Alarm”>
soapenv:Header/
soapenv:Body
cen:GetAlarmLines
<cen:token>TOKEN#6b27d525-1ccd-46e0-8276-919f01b12919#rthd-xms01.rthd.intra//ServerConnector#</cen:token>
<cen:maxCount>10</cen:maxCount>
<cen:filter>
<vid:Conditions>
<vid:Condition>
<vid:Operator>Equals</vid:Operator>
<vid:Target>ObjectId</vid:Target>
<vid:Value>1</vid:Value>
</vid:Condition>
</vid:Conditions>
</cen:filter>
</cen:GetAlarmLines>
</soapenv:Body>
</soapenv:Envelope>
throws this answer :
<s:Envelope xmlns:s=“http://schemas.xmlsoap.org/soap/envelope/”>
<s:Body>
<s:Fault>
<faultcode xmlns:a="[http://schemas.microsoft.com/net/2005/12/windowscommunicationfoundation/dispatcher](http://schemas.microsoft.com/net/2005/12/windowscommunicationfoundation/dispatcher)">a:DeserializationFailed</faultcode>
<faultstring xml:lang="fr-FR">Le module de formatage a généré une exception en tentant de désérialiser le message : Une erreur s'est produite en tentant de désérialiser le paramètre [http://videoos.net/2/CentralServerAlarmCommand:filter](http://videoos.net/2/CentralServerAlarmCommand:filter). Le message InnerException était 'Aucun contenu enfant de l'élément Value provenant de l'espace de noms [http://schemas.datacontract.org/2004/07/VideoOS.Platform.Proxy.Alarm](http://schemas.datacontract.org/2004/07/VideoOS.Platform.Proxy.Alarm) ne peut être désérialisé en tant qu'objet. Utilisez XmlNode\[\] pour désérialiser ce modèle de XML.'. Pour plus d'informations, consultez InnerException.</faultstring>
</s:Fault>
</s:Body>
</s:Envelope>
I don’t know how I can send correct value for condition.
Do you have some examples?
The value would be the GUID (the camera GUID in this case).
Off course, I tried with a guid but the error is always the same.
For example, the following request:
soapenv:Header/
soapenv:Body
cen:GetAlarmLines
<cen:token>TOKEN#7cf096c5-8617-47e6-a3bc-03a46f7b55bd#rthd-xms01.rthd.intra//ServerConnector#</cen:token>
<cen:filter>
<vid:Conditions>
<vid:Condition>
<vid:Value>58dd92f0-e02b-4b12-aad6-f474d9999166</vid:Value>
</vid:Condition>
</vid:Conditions>
</cen:filter>
</soapenv:Body>
</soapenv:Envelope>
is giving me the anwser :
<s:Body>
<s:Fault>
</s:Fault>
</s:Body>
</s:Envelope>
So i don’t know how to format condition value to a be valid.
Do you have any idea?
I think you are missing the type for the Value parameter. So add something like this in the main Envelope node:
xmlns:inst=“http://www.w3.org/2001/XMLSchema-instance” xmlns:sch=“http://www.w3.org/2001/XMLSchema”
And then change the Value node to something like this:
<vid:Value inst:type=“sch:string” >58dd92f0-e02b-4b12-aad6-f474d9999166</vid:Value>
If this does not work please try to do a trace of communication from Smart Client and compare to your code.
