I’m writing a plugin to SmartClient 2017 R3.
When querying the Location property of ImageViewerAddOn, I usually get X indicating the left edge, and Y indicating the top.
After changing SmartClient’s settings, to work in right-to-left language, X started to indicate the right edge.
Is this behavior intentional?
If so, is there a property in the API to query from, in order o know if text mode is right to left?
Thank you
