Hi ,
ImageViewerControl in plugin is always providing 8fps only, is there any setting we need to set , so it can stream higher fps
Hi ,
I just checked with the VideoPreview sample in the Smart Client and it is running at the same frame rate as normal camera items. How and where do you see this?
Please try enable diagnistics overlay (Settings->Advanced->Video diagnostics overlay=Level 3) and then compare the “Frames per second” reported in your plugin and a normal camera item showing the same camera.
my bad, fps was limited in camera. now its fine
