ImageViewerControl needs to be on a UserControl before Initialize is called
Since we cannot see the ImageViewerComponent in toolbox to directly add it into the designer, I am trying to explicitly add the ImageViewerControl into our panel
But I am getting error:
here is how I am adding it explicitly
Private Sub InitMilestoneComponents()
Const FunctionName As String = "clsMilestoneWrapper.Init"
Try
  Dim selectedCamera = clsMilestoneShared.EngineManagerConnectToServer(Me.mParentForm, 1, 12, 1)
  Me.mParentForm.SplitContainer1.Panel1.Controls.Add(LiveMilestone)
  Me.mParentForm.SplitContainer1.Panel2.Controls.Add(EventMilestone)
  LiveMilestone.CameraFQID = selectedCamera.FQID
  EventMilestone.CameraFQID = selectedCamera.FQID
  LiveMilestone.Initialize()
  EventMilestone.Initialize()
  LiveMilestone.Connect()
  EventMilestone.Connect()
  MilestoneImageViewerEnableEvents(LiveMilestone)
  MilestoneImageViewerEnableEvents(EventMilestone)
  MilestoneImageViewerSetHandlers(LiveMilestone)
  MilestoneImageViewerSetHandlers(EventMilestone)
Catch ex As Exception
  dbg.LogError(FunctionName, "Error - " & ex.Message)
End Try
End Sub
LiveMilestone and EventMilestone is generated as
  mLiveClientControl = ClientControl.Instance
  mEventClientControl = ClientControl.Instance
  LiveMilestone = mLiveClientControl.GenerateImageViewerControl()
EventMilestone = mLiveClientControl.GenerateImageViewerControl()
Just in case, I tried using ImageViewerWpfControl too
If you do this after InitializeComponent() there should be a UI and we cannot see why you would get the error you observe.
I suggest you look at a sample (I recommend VideoViewer) and see the order of things in that sample. Now that sample was changed to use WPF, and that is the general recommendation. But if you want this sample in WinForms you will need to navigate to the 2023R2 version of the samples.
https://doc.developer.milestonesys.com/html/index.html?base=samples/componentsamples/videoviewer/readme.html&tree=tree_2.html
The ImageViewerWpfControl should be usable in the XAML designer directly.
