We are experiencing a problem with using the SDK and ImageViewerWpfControl, as used in the samples found on your github repository (Examples: VideoViewer and VideoViewer2Playback).
When we connect the client to a multicasting camera (XProtect Corporate), we get the following exception:
Exception thrown: ‘System.InvalidOperationException’ in WindowsBase.dll
MIP: Error: MulticastConfig (): The calling thread cannot access this object because a different thread owns it.
This exception is thrown from inside the SDK.
When this happens, no video is shown in the WpfControl.
This is an issue that often happens when not handling UI actions on the UI thread. We suspect that somewhere inside the SDK, an attempt to call Task.Run causes this issue.
We have tried the most recent available versions of the .DLL’s from nuget.
There is no problem when multicast video is disabled in the server.
