The parameter description of the ImServerCommandServiceClien.login method.
How long is the validity of this method at a time.
Check the ‘TimeToLive’ field for how long a token is valid.
Thanks! How to check?
Can you provide sample source?
You can set a break point in this code, and see what the TimeToLive contains
