I installed XProtect Professional+ 2025 R2 and Open Network Bridge 2025 R2, and I want to play back as an ONVIF client using VLC Media Player’s network stream (RTSP).
Configure user settings for an ONVIF client 2. In the Management Client, create a role that can access cameras, and specify permissions for the Milestone Open Network Bridge security group on the Overall Security tab for the role.
Could you advise on the cause and how to resolve this issue?
I am also experiencing this issue. I have the bridge plugin installed for my 2025 R2 management client.
I see the “Open Network Bridge Server” under “Servers”, but there is no New option, as described in the documentation. There is also no “Open Network Server” permission group in the “Overall Security” tab.
Hi @Kouzou
I am unable to reproduce the issue with the official 2025R2 build (16119).
I’d recommend that you connect Milestone Support for proper help, since it looks more like a configuration issue or a bug, and not a development-oriented question.
